UI7 ▾ Version 7.0.15 (1.7.830/1.7.2043/1.72044) ▾ July 12th, 2016
Who will be first?
Firmware
Vera3, VeraLite, & VeraLite G: 1.7.830
VeraEdge: 1.7.2043
VeraPlus: 1.7.2044
New Feature
Enrollment on WEB UI and iOS
Add device wizard on iOS app
Geofence support for multiple users
Samsung Appliances integration
Improvements
Mobile Apps Optimizations
Vera Plus network optimizations
Server infrastructure stability improvements
Improvements for Wi-Fi and Network scripts and interface
WEB UI loading speed optimizations
Improvements and fixes for device pairing wizards
Mobile Backend loading speed improvements (iOS)
Luup Engine Optimization
Updated SMS & Email Notifications
New Integrated Devices
ZigBee
Micro Motion Sensor 3 Series 3328-G
Micro Door/Window Sensor 3323-G
Z-Wave
Fibaro Door Window Sensor FGK-101 GEN5
Fibaro Motion Sensor FGMS-001 - GEN5
Fibaro Flood Sensor FGFS-101 GEN5
Fibaro Dimmer 2 FGD-212 - GEN5
Fibaro RGBW Controller FRGBWM-441 GEN3 - basic integration
Fibaro Flood Sensor FGFS-101 GEN3 - extended
Fibaro Door Window Sensor FGK-101 GEN3 - extended
Fibaro Motion Sensor FGMS-001 - GEN3 - extended
Vision MultiSensor 4 in 1 ZP3111 - GEN5
Aeotec Door/Window Sensor ZW120 GEN5
Aeotec Smart Energy Switch ZW075-GEN5
Aeotec Dry Contact Sensor ZW097 GEN5
Aeotec Door Window Sensor 6 ZW112 - GEN5
GoControl Battery-Powered Thermostat TBZ48 - GEN3
Stelpro Electronic Thermostat STZW402 GEN5 (only on WEB) with Known Issues as: Wrong setpoint displayed for ~ 1 second when you switch from “OFF” to “HEAT” mode; Notifications for “Eco” and “Off” mode - missing for Stelpro thermostat for the moment
Qubino Flush 1 Relay ZMNHAD1 - GEN5
Qubino Flush 1D Relay ZMNHND1 - GEN5
Qubino Flush Dimmer ZMNHDD1 - GEN5
Fixes and Improvements done on DEVICES:
RGB Bulbs can?t turned ON and OFF from android app
Aeotec Siren ZW080-C15-GEN5
Aeotec Multisensor 6 GEN5 - UV sensor doesn?t work
Aeotec Switch RGB LED Bulb ZW098-GEN5
GoControl Siren & Strobe WA105DBZ-B
Vision Door/Window Sensor ZD2102-5 - GEN5
Aeotec Smart Energy Switch DSC24-GEN3
Aeon Labs SmartSwitch DSC06106 GEN3
Aeotec Panic Button DSA38 GEN3
Aeotec GEN5 Garage Door Controller ZW062 - Current Bugs depends on our collaboration with the Manufacturer
GoControl Dimmable LED Indoor Flood Light LBR30Z-1 Gen5
Aeotec Micro Dimmer 2nd edition DSC27103 GEN3 (Known Issue: Delayed status update on manual operation)
OTHER FIXES
Fixed Camera streaming doesn?t work when user activates Secure Vera
Improvements for camera streaming on Android
Fixed Camera’s videos or snapshots are not displayed on recorded tab
Improvements for VistaCam PT
Improvements for Vistacam 700
Improvements for Danfoss radiator
Improvements for Vision Glass Break Sensor ZS5101-GEN3
Fixed error in lua for scenes and events
Fixed Light sensors display values in “%” instead of “lux”.
Fixed Storage events issues when storage call fails
Fixed Special characters are not displayed properly in scene names and notifications
Fixed Recorded video for Vistacam 1100 starts from random position
Fixed Push notification not received on iOS
Fixed Insteon PLM modem crashes VeraPlus
Fixed Everspring ST814 cannot configure on UI7
Fixed engine reload restores the alerts deleted with the delete data request
Fixed Duplicate alerts generated for the same event on some cases
Fixed Recording is not working if the camera password contains special characters
Fixed Moving from/to different network renders network unreachable on VeraPlus
Fixed Vera plus errors “Zigbee: Failed To Start” and LuaUPnP restarting
Fixed Add wizard for adding cameras using WPS on VeraPlus
Fixed Detection issues for VistaCam cameras on VeraPlus
Fixed Nest thermostat doesn’t have the mode controls in the Devices tab
Fixed Unable to add daily restrictions for pin codes
Fixed error “Ergy gateway serial is not present in user” on VeraEdge
Fixed “Exit” button from “Other Bluetooth device” wizard not working on VeraPlus
Known Issues
I2/I3 Inputs cannot be triggered for Qubino Flush 1 Relay, Flush 1D Relay, Flush Dimmer
(Android) Cannot set mode for Samsung devices in scenes
Status not received when Aeotec doorbell is manually activated
Unable to control Revogi bulb
Unable to close Aeotec Garage Door Controller ZW062 using the toggle switch (from device itself)
Linear/GoControl WAPIRZ-1 doesn’t untrip
Garage Door Assets Not Displayed Correctly
VeraPlus cannot add cameras in some cases using WPS button
Already done. Minor issues, but seems to be running better than before. This is not a recommendation, just my experience.
EDIT: This time I resisted messing with things for about an hour. All my devices woke up and configured correctly. With Vera you always have to be patient!
I swore I wasn’t going to upgrade unless I absolutely had to, but I was weak. Fortunately, it loaded in less than 10 minutes and everything seems to work.
Don’t watch the LEDs while it is upgrading. Start the upgrade and leave for a while. If you watch it you will go crazy and curse it!! :smiley: :smiley: :smiley:
LOL - I read the beta thread and watched it like a hawk. No issues for me, all smooth. I have a static IP as others did and there was no issue during this upgrade on the VL. I’m watching the supposed Luup engine optimization and really hope that will actually benefit me.
Only odd thing I encountered was post the VL upgrade, two scene notifications triggered to my phone. Those 2 scenes are set for sunrise but looking at the last run time of the scene in the UI it was this morning like it should have been. No biggie I guess.
I had the same thing happen. Three notifications from earlier in the day were sent again.
Upgraded, all clear two hours in. Definitely seems like the UI is faster. Will see how it goes the next few days.
No issues with either the Plus or the Edge. But both were on the beta already without issues. No fix for the Vision smoke sensor showing always alerting yet which I reported on the beta. Hopefully the next firmware has a fix and won’t be 6 months away.
My two problems still not fixed. I have a ghost Device error “Device failed to configure” and all my battery devices still show battery level of 100% and the batteries are not 100%. I have been waiting since March to add anything else to my Vera Plus. I’m tired of waiting. I did the Firmware upgrade today and that was a mess. I have never owned a device that has so many problems.
[quote=“KenJ, post:1, topic:192986”]New Integrated Devices
Z-Wave
Known Issues
I2/I3 Inputs cannot be triggered for Qubino Flush 1 Relay, Flush 1D Relay, Flush Dimmer[/quote]
What does this mean? I’m still running the previous version and have the Qubino Flush Dimmer ZMNHDD1 (zwave plus) and the ZMNHDA2.
Only the ZMNHDD1 won’t trigger the I2 and I3 inputs. Does this update break the ZMNHDA2 or is the issue with the ZMNHDD1 still not solved?
Hmm - After upgrade I have lost my Vera Plus on the network - times out on its fixed IP, and doesn’t ping either. Checked my DHCP server I see that it has tried to acquire a new dynamic IP but it times out accessing that too. Left it for an hour and then rebooted - still the same. I hadn’t previously installed the beta.
So I login to getVera I can see the controller and if I select it then it connects but curiously not locally - it still uses the WAN address. I can now however check and see that it has reverted to DHCP* and I can see the address it acquired (which matches the router info) . However I still can’t connect locally using that address or even ping it - which is very strange and a bit contradictory as the WAN access is working. Any ideas ?
K
  • I saw this reversion to DHCP raised as a bug as soon as the beta was released - I can’t believe that Vera just ignored customer feedback on the beta and released the final version with that bug still there ! After all what are betas for but to catch and fix these issues .
Has that happened to anyone else? I have my mine configured for a fixed IP address, as with everything else in my house. I don’t want it going haywire changing to DHCP on it’s own.
I know this is not helpful at this point, but this is why I assign IPs thru my DHCP server vs static IPs. Same result but you don’t have to worry about losing a device if something goes wrong, or if I rogue device conflicts with your static IP.
I used to do that. But then when my router has to be reset or replaced, the whole IP address scheme is gone.
Reverting my Vera to static IP seems to have worked and I can now access it locally - however it is showing offline via the Vera portal even after logging out and back in :frowning:
On initially doing this I again couldn’t access the Vera locally - I just got the Vera logo top left (some progress) and a spinning green wait circle - which eventually timed out with a ‘Luup engine taking too long to reload’ error message. I couldn’t fix this despite reloading the engine - and a power cycle but it has now eventually loaded but with local access only. The controller remains offline in the Vera portal.
There is almost nothing installed on this Vera Plus as I have two other main controllers still, a UI5 Vera Plus and a UI7 Vera Lite.
K
Update:
 Also just noticed that WiFi was re-enabled after firmware update :-(
 The portal has now picked up the  controller on its static IP- so all is well but all of this could have been avoided by Vera paying attention to the beta feedback.  I assume that as some static IP users are not seeing this  that it varies depending on... if you have already installed the beta or perhaps from what base firmware version you are upgrading.  There were several previous firmware versions of the Vera Plus out there it seems.  I have my Vera Lite to update now so I will see if the same thing happens with that.
Indeed - I too prefer the router to reserve IP’s but it has a limited number that it can reserve and I’m already using them all so there are a few devices I have to manually assign.
xAPPO: I had the same problem. The fix for me was to go to the Vera portal and unassign and reassign the unit. Good luck.
Upgraded my Vera Edge. Took about 8 minutes. No issues and everything seems to be in order.
Have about 50 devices and a handful of Sonos devices controlled by the Sonos plugin.
Does the new version make backups from the prior version incompatible? Or should it work fine if I have to reset and restore after the update?
Just did the upgrade on my Edge and all working as before. They fixed my camera issues (device was not responding but working fine). No more message from my cameras
