UI7 Support for PLEG/PLTS plugins
[quote=“RichardTSchaefer, post:16, topic:182640”]You should be able to change actions now using LOCAL access.
I am waiting on MCV to fix a bug in the APP store so I can release the fix to allow Actions using Vera connected remotely.[/quote]
Thanks for the work-a-round, that solved the issue. For other, you have to take your Vera out of secure mode if you want to access it locally.
MCV is still trying to fix the App Store bug so I can release my fix for editing actions remotely.
Added an action on immediate tab assigning a basic action to turn on a light when a condition is true, sadly the system is not performing any action. The status report shows that the condition is true and the actions that are supposed to be executed, but no luck. When I run a vera scene with the same action all works. what could I be doing wrong?
