Vera 3
UI7 1.7.690
I have been holding off on the UI7 upgrade for a long time. I have tried it a few times and it failed miserably. This is the FIRST revision that I actually can stand. I am not getting weird device disconnects anymore like I had with previous tries. But I am still having problems with command execution.
Whenever I send it a device or scene command from either the Vera Mobile app, web interface or like so, it could take 10-15 seconds to MAYBE execute it. This issue doesn’t happen immediately, but after an hour or two after a restart. It becomes wildly unpredictable. After a restart it is fine for another hour or two. What gives?
What can I do to try and determine why this delay appeared after the update?
Below are a few metrics when the problem is occurring. Nothing obvious unfortunately.
top:
Mem: 43048K used, 84408K free, 0K shrd, 0K buff, 20664K cached
CPU: 6% usr 5% sys 0% nic 87% idle 0% io 0% irq 0% sirq
Load average: 0.28 0.24 0.23 1/70 8257
PID PPID USER STAT VSZ %MEM %CPU COMMAND
6341 2067 root S 66108 52% 2% /usr/bin/LuaUPnP
1966 1 root S 748 1% 1% /usr/bin/luci-bwc -d
2454 2339 root S 7016 5% 0% /usr/bin/NetworkMonitor
7730 4950 root R 1680 1% 0% top
2393 1 root S 4236 3% 0% lighttpd -f /etc/lighttpd.conf
545 1 root S 1928 2% 0% syslogd -C256
2285 1 root S 1848 1% 0% /bin/sh /usr/bin/cmh-ra-daemon.sh 127
1880 1 root S 1696 1% 0% crond -c /etc/crontabs -l 5
2067 1 root S 1688 1% 0% /bin/sh /usr/bin/Start_LuaUPnP.sh
1 0 root S 1684 1% 0% init
4950 4147 root S 1684 1% 0% -ash
513 1 root S 1684 1% 0% init
1997 1 root S 1680 1% 0% watchdog -t 5 /dev/watchdog
2339 1 root S 1680 1% 0% /bin/sh /usr/bin/Start_NetworkMonitor
2090 2067 root S 1676 1% 0% /bin/sh /usr/bin/Start_serproxy.sh
547 1 root S 1672 1% 0% klogd
7850 2285 root S 1668 1% 0% sleep 58
2325 2285 root S 1216 1% 0% ssh -p 232 -T -y -i /etc/cmh-ra/keys/
4147 586 root S 1200 1% 0% /usr/sbin/dropbear -P /var/run/dropbe
586 1 root S 1128 1% 0% /usr/sbin/dropbear -P /var/run/dropbe
free:
total used free shared buffers
Mem: 127456 42952 84504 0 0
Swap: 0 0 0
Total: 127456 42952 84504
