I have no longer any control buttons (Google Chrome on windows) available for my PTZ cam?
Its a basic foscam using I_WintopZCamPTZ.xml
It used to work in UI5.
I do have them for my vera pt. Wish they could make it so you can jog the pan and tilt. Right one the controls are pretty useless because it just runs away until it hits the end of travel. Also need access to presets so we get around this and go to our favourite positions
I got this working last night with my Foscam p/t camera…i also use the impl_file: I_WintopZCamPTZ.xml
I installed the Wintop zCam IP Camera plugin which does seem to be required.
Also set the mac address… not sure if this is really req, but i recall it from other threads…NFI why it would be needed!
edit: Also set the “commands” variable to this camera_up,camera_down,camera_left,camera_right,camera_full_screen,camera_preset,camera_archive_snapshot
