Can’t log in… another login issue…
its back up
Lats weeks I am experiencing problems with the portal for remote login. Also imperihome doesn’t work remote then. The status page is “all ok” but I can’t connect remotely.
Vera support also confirms no issues are known. But me, and 2 friends also owning vera’s do have the problem on the same times.
Is anyone alse also experiencing such remote login issues?
Local login, and local imperihome works always well, also during remote login problems.
I’ve had some reports from HomeWave users having issues to connect remotely. It seems to be intermittent, if they try again later or via the portal, suddenly things are working again,
Yes, intermittent is the right word. Sometimes it suddenly works, some not
Anyone having issues logging in via home.getvera.com currently? I enter my user and password and the “checking credentials” continually spins. Looked in the browser console and there was a Json error on the page (should have copied it but now I’m on mobile). Anyone else seeing this?
It is working for me… at this time.
