UI7-PLEG Set Mode (Home, Away, ...)‏
Per R Schaefer:
Add the PLEG as the device in your Actions, Select the SetHouseMode action.
Specify the House mode
For the values see:
http://wiki.micasaverde.com/index.php/House_Modes
Thank you to Richard…
Has anyone experienced problems (or had success) using PLEG to set the house mode, using the latest firmware? My condition triggers ok but the PLEG action to SetHouseMode=2 doesn’t seem to work. It should switch from home to away but it stays in home.
