UI7 Pleg Scene
I have searched and can not find an answer. Can someone please tell me: Is there a way to use a scene in an ACTION using UI7. I have done it in the past with UI5, but do not see how to do it with UI7.
Help?
This may be a better tread to post this question in. I believe that, Richard the author of PLEG, monitors this tread.
http://forum.micasaverde.com/index.php/topic,12759.0.html
In the ADVANCED mode for the Actions editor.
  1. Add the PLEG devices as an action.
  2. Select the RunScene Actiom
  3. Specify the Scene Name or Scene #
Thank you Richard for the reply. PS great App!
So I did what you suggested, but I do not understand how I can get the scene to run as part of an action.
TY
[quote=“margo, post:4, topic:191247”]Thank you Richard for the reply. PS great App!
TY[/quote]
Picture is worth more. Maybe Richards instructions will make more sense now.
Top arrow you need to pick your PLEG device not the scene from the lst which you cant find. Then bottom arrow you can put in the scene name or number. 2 steps and you can’t get to the 2nd without the 1st.
@integlikewhoa thank you!
That pic is worth more than 1000 words.
