After updating to UI7 homewave only allows me to connect to 3g (the cloud appears). I’m inside the same wifi and it does’t connects locally. It is this reason that when I open homewave it takes much longer to load the program and connect to my vera. Is this normal, or is there something wrong with my setting? (I have ui5 disabled)
Thank you.
