I’m I missing something or is there no way to delete a scene trigger in UI7?
When editing the scene, you can select the trigger(s) and once selected, there is a trash can symbol to delete the trigger.
I don’t see a trash can symbol for triggers. The only trash can I see is on the scene.
See attached screen capture.
Try selecting the edit icon. Are you logged into your unit?
Ah, thanks. I wasn’t logged in. That’s odd that it lets you see the whole configuration and change some things without being logged in.
