Hello,
I just go in UI7 and I encounter problems on trigger with HSM02.
Here is what is configured:
If a detector is armed and opened or closed then sends a notification via a piece of Lua code.
It works perfectly well when I open or close the door, except that every 30 minutes, I get a notification as if there was a trigger.
If I look a little the module configuration, there is the wakeup interval to 1800 seconds (30 minutes), so I feel that once the module wakes up, it triggers the scene.
Do you have an idea or behavior to solve my problem?
Thank you for your help.
Sample from my logs: The scene 14 is launched but the door was not closed, it’s only a wakeup of the 35 device (HSM02)…
02 11/10/14 20:55:31.101 ^[[33;1mLOG_CHECK_MEMORY_LEAK pMem start 0xb0f000 now 0xb2e000 last 0xaf0000 leaked 126976^[[0m <0x2c1da680>
06 11/10/14 21:08:40.999 Device_Variable::m_szValue_set device: 35 service: urn:micasaverde-com:serviceId:ZWaveDevice1 variable: ^[[35;1mLastWakeup^[[0m was: 1415637511 now: 1415639320 #hooks: 0 upnp: 0 skip: 0 v:(nil)/NONE duplicate:0 <0x2c1da680>
06 11/10/14 21:08:41.149 Device_Variable::m_szValue_set device: 35 service: urn:micasaverde-com:serviceId:SecuritySensor1 variable: ^[[35;1mTripped^[[0m was: 0 now: 0 #hooks: 2 upnp: 0 skip: 0 v:0x9258a8/NONE duplicate:0 <0x2c1da680>
07 11/10/14 21:08:41.150 Event::Evaluate 2 scene Alarme Salon - Ouverture is false repeat 0/-1 <0x2c1da680>
07 11/10/14 21:08:41.150 Event::Evaluate 5 scene Alarme Salon - Fermeture is true users:1114645 allow:1 <0x2c1da680>
08 11/10/14 21:08:41.150 Scene::RunScene running 14 Alarme Salon - Fermeture <0x2c1da680>
06 11/10/14 21:08:41.522 Device_Variable::m_szValue_set device: 35 service: urn:micasaverde-com:serviceId:SecuritySensor1 variable: ^[[35;1mArmedTripped^[[0m was: 0 now: 0 #hooks: 0 upnp: 0 skip: 0 v:0x934b30/DL_ARMEDTRIPPED duplicate:1 <0x2c1da680>
06 11/10/14 21:08:41.523 Device_Variable::m_szValue_set device: 35 service: urn:micasaverde-com:serviceId:SecuritySensor1 variable: ^[[35;1mLastTrip^[[0m was: 1415637511 now: 1415639321 #hooks: 0 upnp: 0 skip: 0 v:0x92ccb8/NONE duplicate:0 <0x2c1da680>
04 11/10/14 21:08:41.524 <Job ID="12" Name="pollnode_wake #5 1 cmds" Device="35" Created="2014-11-10 21:08:40" Started="2014-11-10 21:08:41" Completed="2014-11-10 21:08:41" Duration="0.523849000" Runtime="0.521593000" Status="Successful" LastNote="" Node="5" NodeType="ZWaveBinarySensor" NodeDescription="D..tecteur Sal
04 11/10/14 21:08:41.620 <Job ID="13" Name="Wakeup done 5" Device="35" Created="2014-11-10 21:08:41" Started="2014-11-10 21:08:41" Completed="2014-11-10 21:08:41" Duration="0.618581000" Runtime="0.93923000" Status="Successful" LastNote="SUCCESS! Transmit was OK" Node="5" NodeType="ZWaveBinarySensor" NodeDescription="D
