UI7 and GE Caddx Plugin
I’m on VeraPlus with UI7 and my Caddx plugin works fine. On my apps page it looks like I’m on v81. I’m connected through the NX-584 and a USB-Serial adapter and I have had some random connection loss there that’s usually solved with a reboot. Unfortunately I have not automated a way to detect and correct that issue so I just keep an eye on it.
As far as I know you should be able to install from the app install page, but if you download the files from Github I suspect you can just upload them on the luup files page.
I am on UI7 using the CADDX, NX-584, and an IP Serial connection through WizNet. Can’t remember a disconnect ever. It just works.
I’ve recently migrated from a VeraLite/UI5 system to VeraPlus/UI7 and have Futzle’s CADDX plugin working perfectly - no drama at all.
I had to make a configuration change on the alarm panel regarding zone bypass and remembering that now the plugin doesn’t directly control the alarm panel state like it did on UI5. This is discussed here: [url=http://forum.micasaverde.com/index.php/topic,26553.msg266853.html#msg266853]http://forum.micasaverde.com/index.php/topic,26553.msg266853.html#msg266853[/url]
If you need to make any serial port configurations they can’t be changed via the CADDX “connect” menu in UI7 - but it will show the current settings. You need to go into the “develop apps” section and find the “serial port configurations” section there.
I understand from other posts, here, that the current Caddx Plugin files are on GitHub. I looked at them, but really don't know what to do with them. Do I just download all of them (6+ files)? Then how do I load them into UI7? Does the order of loading them matter?
At one time I’m sure Futzle’s Github files were more recent but you can see that they haven’t been changed in 3+ years. I installed directly from the Vera app store and also downloaded the files from Github to compare, and did not see any differences. So while downloading from Github and uploading them via APPS/DEVELOP Apps/LUUP files /UPLOAD menu is a very easy drag and drop process, you don’t need to in this instance.
