[quote=“YzRacer, post:38, topic:182482”][quote=“futzle, post:37, topic:182482”]Thanks for confirming that the change works for you. I’ll include it in version 82 so you won’t need to patch the file manually again.
I’m afraid that I’ve got no suggestions about the remote arming away/stay conundrum. My NX-4 hasn’t been configured that way so it’s always Worked For Me. I guess you could just try it and see. (To be honest, I didn’t know that the Caddx alarm suffered from this “feature”; there’s a great deal of discussion on the DSC alarm forums about a very similar behaviour, which I thought was limited to that system. So I learned something.)
The whole House Modes fiasco in UI7, where you have to specify Arm or Bypass for every sensor without the option to leave its state unchanged, is why I’m now recommending you go back to your NX-584 or NX-8E and disable the Toggle Zone Bypass message in the interface. You lose the ability to bypass a zone from Vera, but you don’t run the risk of a house mode change disabling your entire security system.[/quote]
Thanks for such a quick fix! I have been reading the NX8 manual and if I just disable the auto bypass I think it will kill the remote arming issue. It’s not even that big of a deal if it goes into stay mode as long as it gets disarmed from the app instead of opening the door. I’m really just happy to see a detailedarmmode so I can use the system to trigger scenes.
I don’t mind the toggle zone bypass, as I am always deployed and I prefer to have the capability to make changes remotely. From my little bit of testing yesterday it appears that a house mode change won’t disable anything, as I can only get the Caddx to bypass a sensor when I toggle it individually in Vera. Since I am always away I am would even consider entering the program mode from your plugin if that is possible. Getting my girlfriend to make changes at the keypad is not my preference.[/quote]
Futzle, thanks again for all of your help with UI7. I have been busy reading the forum and learning all about the Vera and I feel like I have gained a lot of knowledge in the last couple of months. I want to clarify a couple of things I mentioned:
My system will arm remotely without a door being opened/closed for a proper “exit”. I have successfully done that several times when my girlfriend left without arming.
A motion sensor can be bypassed with the Vera. It doesn’t work well with mode changes unless your patterns are very specific since there are a lot of variables involved. I am currently using PLEG, with a condition that will bypass my interior problem zone whenever the system is “Ready” for > 1 minute. As I mentioned before attempting to bypass a zone when in exit delay or armed mode can cause issues, so it’s best to avoid that situation.
Your fix for the continuous ExitDelay indication on the UI7 dashboard is holding up well, however I have noticed some issues with PLEG:
Using triggers to monitor detailed arm mode status doesn’t always work. For some reason PLEG doesn’t see triggers as true when they are in fact true or it may see triggers as true when they are false. I suspect this may have something to do with the fix you implemented but I am not certain. I have had better luck using device properties with PLEG and monitoring the detailed arm mode with conditions of eq “ExitDelay” and such. This always works well for Armed and Ready modes, however today I noticed it missed “ExitDelay” twice. I’m not 100% certain that isn’t an issue with the order of my PLEG conditions but I would think it should identify true when the state changes and is true. I’ve attached my PLEG status report for your review if you are interested. It clearly shows some discrepancy between the triggers and the device properties.
