UI6/UI7 compatibility
I don’t get the icons ???
If you are talking about the device icon (and not the album art), yes I know, it is normally the only thing that does not work. It will be fix later, when I will run UI7 and we got information from Micasaverde.
Version 1.1 compatible with UI7 is now released.
Hey it worked like a charm on UI7. Thanks lolodomo for releasing this version 8)
My experience with new release:
  1. I copied Sonos.png files to folder “/www/cmh/skins/default/icons/device_states” and used upload feature for rest of the xml, js etc. but couldn’t see the Sonos in device list.
  2. Then I installed Sonos 1.0 from Apps using install Apps on UI7 and made sure I see the Sonos in devices but yeah it was not working (Don’t worry)
  3. Then I copied Sonos.png files to folder “/www/cmh/skins/default/icons/device_states” and used upload feature for rest of the xml, js etc.
  4. I tried Discover option but it failed to show-up anything.
  5. Then I tried search by IP address and found my Sonos device
This worked like a charm. I could see Sonos Zones in Groups (not tried them yet).
I can see the Sonos on UI7 using IE9 and Chrome on Windows 7, IE11 and Chrome on Windows 8.1. 8) :smiley:
Will experiment with this and will have feedback on TTS once I try it.
I tried today to discover the zones. It is working for me now.
As I mentioned in another topic, you probably forgot to clear your WEB browser cache just after the creation of the Vera device.
Thank you for the information, that’s good to know that the discovery is working for you too.
