UI6 and My Alerts
A while back I installed UI6 on one of my VeraLites, I figured I would give it a try on only one unit to simple check it out.
Since the update entries under My Alerts have been coming fast and furious! The interface shows 84 pages of entries and I’ve deleted multiple pages and it show there are 84 pages. I am assuming there are many more than 84 but the interface only allows you to select from the first 84.
Two questions:
  1. Prior to installing UI6 I was getting very few alerts, why so many now?
  2. Is there a way to clear ALL alerts? The interface only allows deleting a page at a time which is very time consuming! I was hoping there is a way to clear all the alerts via SSH or some other method.
I have noticed that as well … I consider it a bug.
For Example I have an event that fires when the OutSide Temp > 36.
On UI5 it fires when the temperature changes from below 36 to above 36.
On UI6 it fires every time the temperature changes and the temperature is above 36.
they must have added an underscore to that subroutine!!
PLEG humor…
:wink:
