UI5: Variables are incorrectly cut
A label or variable defined in a scene group with an x value (width) defined as greater than 1 still has it’s text cut at 11 characters (and appended with “…”) even though it should allow longer strings (11*x at minimum).
Example attached. The date field is defined as x = 2 right align, the second row (“A door” is defined with x=3 and text_align center.
I can confirm. We will fix this after we return from vacation.
The ellipses appear other places it need not. The name of my device fits, but ellipses are still appended for no apparent reason.
The ellipses appear other places it need not. The name of my device fits, but ellipses are still appended for no apparent reason.[/quote]
Sigh. And to paraphrase the WWII slogan: “Loose ellipses sinks shipses”…
Bug entered:
http://bugs.micasaverde.com/view.php?id=2095
@mcvflorin
Any progress on fixing this bug? Please raise the priority of the bug.
[move]This is basic functionality that needs to be fixed ASAP.[/move]
@Ap15e
I don’t like this bug either, so I spent 2 hours last Friday trying to fix this bug with no success. I’ll try to convince Aaron to get the UI team to fix their assigned bugs, though I’m pretty sure this won’t happen before the new firmware is out.
Thanks!
