UI5 Trigger Alerts, need to thin them down!
Im running UI5 and have trigger alerts setup for my gate via a door/window sensor. The problem I am having is the “alerts” are way too bloated.
Here is an example of what shows up on my SMS / email.
“(Notification) Trigger:Gate Open, device:26 Gate Sensor in , details:Tripped=1, alert #5171649051, serial #35020551
Is there an add on or a way to tweak this so that it can be simplified? When I’m in hands free mode with my phone in my car I don’t want to hear all of that when I open something or trigger something.
And yes I did search the forum but most of the posts are referring to UI7. I’m not upgrading to that until it gets better options & stability.
Thanks in advance.
Using the Vera Alerts Plugin allows you to customize the alert message.
There are LOTS of ways to deliver the messages to your phone … On Android they can be spoken to you.
I was looking at that but I’m having a hard time wrapping my head around it. I just installed it but I can’t figure out how to set it up. I am wanting to have it send an email and also an SMS to my phone. I really don’t want to have to add another app to my phone to make things work.
I just want “simple” notifications like…
“Gate open at 11:24am” or “Left garage door open at 12:03pm” or “Alarm deactivated at 5:00pm”
Just looking for notifications, not an in depth summary. If its something I’m concerned about I can access it directly through my apps or browser.
[quote=“Shoktronic, post:3, topic:186717”]I was looking at that but I’m having a hard time wrapping my head around it. I just installed it but I can’t figure out how to set it up. I am wanting to have it send an email and also an SMS to my phone. I really don’t want to have to add another app to my phone to make things work.
Just looking for notifications, not an in depth summary. If its something I’m concerned about I can access it directly through my apps or browser.[/quote]
Using the app is simple, and makes it look clean. Gives you a pop up alert with the time and notification, as said it can be spoken to you. If you click on it or open the app it give a nice log layout of times and days of what happened. If you have cameras when an alert is sent a snapshot can also be sent with that notification.
Sending Emails and SMS don’t get a nice format and clutters things up let alone using both. That’s a double notification on the same device.
Vera Alerts you can set a custom message for your notifications. So you can have it say what ever you input.
Also Vera alerts plugin can be setup to send alerts to Email or pushbullet, prowl or a buch of other places. It doesn’t have to just to go the free Andriod app.
But again I would recommend you try it, its really much nicer and most used method (unless you have an APPLE phone) then prowl probley is.
