Ui5 and danfoss thermostat
I upgraded to ui5. Ivera is working correctly, but the danfoss thermostat are not more recognised.
Are you working in It?
Also the RFID transmitter are not recognised.
Thank you
Matteo
Hello
I have 5 Danfoss connected to Vera Lite and it is working OK.
I had to force some of the Danfoss units to connect to Vera using the buttons on the Danfoss thermostat.
In the Danfoss “Installation and user guide” it is in chapter 4.2 “Testing the connection”, and this procedure is making the connection between between the Danfoss thermostat and the Vera Lite in “learning mode”.
Frank Buthler
