UI4 Upgrade
I just updated to UI4. A few hours went by. I can’t access the device (Vera 2) from findvera.com and when I access it locally I only get a screen that partially lists the devices that I have loaded. I updated with the option to keep the current configuration. Tried power up/down. No change. Any thoughts?
findvera.com is only for UI2 and UI3 users as far as I know. You’ll need to use https://cp.mios.com/ for UI4. As for the partial list, I’ll have to let someone else answer. I’ve yet to venture into the UI4 waters.
Cheers
access UI4 from MiOS
