I recently upgraded to UI4 (with a bit of difficulty) and have found what appears to be a bug. A bug which seems to have appeared in previous versions of the UI, but were fixed.
Problem: If I create a scene which is triggered by an event, and has a command which includes “Unchanged,” when I save the scene, “Unchanged” reverts to “Off” which appears to be the current status of the device included in the event.
My goal is to monitor when a given light is Turned on. This event triggers the scene which has a command of (If) Unchanged - After 1hr - (Turn) Off. When I save the scene and go back in to verify it, the “Unchanged” section, under the command tab has reverted to “OFF”
Rebooted Vera.
Refreshed Browser.
Tried a variety of Switches and devices with this command.
Cannot get it to work.
Comments or suggestions?
Thanks,
Frank
