Ui issues after upgrade to 7.0.6
SOLVED!
I couldnt resist anymore. Wanted my new devices in my vera lite, so upgraded fw to 7.0.6. (1.5.569)
I have some issues now though that is rather frustrating, i get temperature in fahrenheit and 12h time format, and most likely wrong location aswell.
So i goto setting and location.
But each time i get forced to a loginpage for home.getvera.com, i login and try again and again i get the same issues. More menus give me the same behaviour.
A funny thing is, that when i click login i get for a very short moment the UI5 login processing screen aswell, then i get the ui7 homescreen.
Any ideas, should i try factory default it and loose everything?
Only issue is i cant get to the menu to do factory default ;/
EDIT: SOLVED! but saving for when people search for fix to the issue.
Solution: I made a new account at http://www.getvera.com.
