Thanks bgrubb1,
I tried the code with no success.
I’m very keen to sort this and I know I am close. I revisited remotecentral.com and again tried Sony HDMI codes listed there.
The first SYSLOG was captured from the SQ Blaster+ (Firmware P100) using SQ Remote on Apple iOS 7.0.3.
SQ Blaster SYSLOG using SQ Remote (working correctly)
<150> 1 - sq-blaster-172b.local - - 80 - 2013-11-23T02:10:17.530Z,1385172617530 10.64.7.201 23/11 13:10:02.221
<150> 1 - sq-blaster-172b.local - - 31 - 2013-11-23T02:10:17.533Z,10.64.7.42,50836 10.64.7.201 23/11 13:10:02.221
<150> 1 - sq-blaster-172b.local - - 78 - 2013-11-23T02:10:17.552Z,188,(null),INPUT HDMI 1,5,0,1385172617552 10.64.7.201 23/11 13:10:02.241
<150> 1 - sq-blaster-172b.local - - 81 - 2013-11-23T02:10:17.558Z,1385172617558 10.64.7.201 23/11 13:10:02.250
<150> 1 - sq-blaster-172b.local - - 87 - 2013-11-23T02:10:17.563Z,11 10.64.7.201 23/11 13:10:02.255
<150> 1 - sq-blaster-172b.local - - 81 - 2013-11-23T02:10:17.589Z,1385172617589 10.64.7.201 23/11 13:10:02.282
<150> 1 - sq-blaster-172b.local - - 93 - 2013-11-23T02:10:19.547Z 10.64.7.201 23/11 13:10:04.234
<150> 1 - sq-blaster-172b.local - - 63 - 2013-11-23T02:10:19.548Z,1385172619548 10.64.7.201 23/11 13:10:04.235
<150> 1 - sq-blaster-172b.local - - 27 - 2013-11-23T02:10:19.551Z 10.64.7.201 23/11 13:10:04.238
SQ Blaster SYSLOG using Vera (Firmware 1.5.622) (Pronto code supplied by bgrubb1 - does not work)
<150> 1 - sq-blaster-172b.local - - 80 - 2013-11-23T02:19:55.223Z,1385173195222 10.64.7.201 23/11 13:19:39.506
<150> 1 - sq-blaster-172b.local - - 31 - 2013-11-23T02:19:55.225Z,10.64.7.200,42829 10.64.7.201 23/11 13:19:39.522
<150> 1 - sq-blaster-172b.local - - 78 - 2013-11-23T02:19:55.251Z,0,2,0,1385173195251 10.64.7.201 23/11 13:19:39.536
<150> 1 - sq-blaster-172b.local - - 81 - 2013-11-23T02:19:55.259Z,1385173195259 10.64.7.201 23/11 13:19:39.546
<150> 1 - sq-blaster-172b.local - - 87 - 2013-11-23T02:19:55.268Z,17 10.64.7.201 23/11 13:19:39.553
<150> 1 - sq-blaster-172b.local - - 61 - 2013-11-23T02:19:55.272Z,-6,Connection closed.,2992,dc_http1.c 10.64.7.201 23/11 13:19:39.557
<150> 1 - sq-blaster-172b.local - - 61 - 2013-11-23T02:19:55.276Z,-6,Connection closed.,3045,dc_http1.c 10.64.7.201 23/11 13:19:39.561
<150> 1 - sq-blaster-172b.local - - 63 - 2013-11-23T02:19:55.281Z,1385173195281 10.64.7.201 23/11 13:19:39.565
<150> 1 - sq-blaster-172b.local - - 27 - 2013-11-23T02:19:55.286Z 10.64.7.201 23/11 13:19:39.570
Here is the snippet from my Vera log (/var/log/cmh/LuaUPnP.log) for the above command.
08 11/23/13 13:19:48.377 JobHandler_LuaUPnP::HandleActionRequest device: 0 service: urn:micasaverde-com:serviceId:HomeAutomationGateway1 action: RunScene <0x2e27d680>
08 11/23/13 13:19:48.378 JobHandler_LuaUPnP::HandleActionRequest argument SceneNum=21 <0x2e27d680>
08 11/23/13 13:19:48.378 Scene::RunScene running 21 HDMI <0x2e27d680>
08 11/23/13 13:19:48.378 JobHandler_LuaUPnP::HandleActionRequest device: 42 service: urn:micasaverde-com:serviceId:IrTransmitter1 action: SendProntoCode <0x2e27d680>
08 11/23/13 13:19:48.378 JobHandler_LuaUPnP::HandleActionRequest argument ProntoCode=0000 0067 0000 0010 0060 0018 0018 0018 0030 0018 0018 0018 0030 0018 0030 0018 0018 0018 0030 0018 0018 0018 0030 0018 0018 0018 0030 0018 0030 0018 0018 0018 0018 0018 0018 032A <0x2e27d680>
01 11/23/13 13:19:48.426 luup_log:42: SQBlaster: Web request returned status=200 response=<?xml version="1.0" encoding="utf-8"?>
in 46ms <0x2e27d680>
I know the SQBlaster is functioning correctly I just can’t find the correct Pronto code for Vera. The TV’s IR acknowledgement LED does not blink using the Vera whereas it does and works perfectly with the SQ Remote app.
I will again try and convert the SQ Remote backup files for Vera device creation and see if this shows any different codes.
If anyone has discrete Pronto codes for Sony TV HDMI inputs 1, 2 and 3, I’d be grateful if you could share them.
