In my living room I installed TKB dimmer (double paddle) to control light. I’ve made simply scene that when the light below 15 lux and movement are detected by Fibaro multisensor then light in living room is switch on automatically, and opposite, when no motion detected in 5 minutes then Vera is switching off light.
But during watching TV - light adjusted to 30% my Fibaro sensor doesn’t detect any movement and then light goes off.
I want to make scene/mode that when pressing additional switch close to TKB dimmer or even TKB second paddle my light goes to 30% and then scene for switching off never activate. The last one is simple, just put additional condition in above mentioned scene (auto switch on/off light). But how to create another mode/scenario?
I was thinking about association some Virtual Switch, but this is not detected by my TKB, or Fibaro relay. Then I was thinking about activating Fibaro relay without connecting anything to that relay. So reading Fibaro relay status Vera can detect am I watching TV or not. But in this case it is a little bit expensive way to do it. Much cheaper to use some plugin etc.
Any other ideas?
