TV Control/Automation
I’m looking to be able to setup scenes where I can get the TV to go to a specific feature, e.g. “Netflix”. My TV is a Samsung Smart TV is doing this would basically require a sequence of buttons timed appropriately. For some scenes it may require “buttons” from multiple remotes. Is SQBlaster the solution? Even if I dont have an iPad?
For your tv
http://apps.mios.com/plugin.php?id=2248
You have several option for ir control.
SQ Blaster. Will work.
Global Cache family, itach, flex but I am sure that the code has modified for flex as yet.
The samsung plug-in may work for my netflix use case, but some other ideas I had involved going to a specific channel. Since the channel is controlled by my cable box I’m assuming this plug-in won’t work.
depends on what model samsung smart tv you have. i have the one with the blaster and i can control my stereo and settop box and dvd player with the samsung tv and plugin.
Mine doesn’t have an IR extender built in (model un55c7000). The Samsung mobile app does connect but I cant control the set top box (change channel). So if I understand correctly in my situation the plug-in for mios will basically let me do anything I can do with the samsung app (but I could setup “scripts” of sequences). With SQ Blaster though I should be able to control everything correct?
Also, with SQ Blaster I can turn the TV on which I understand cannot be done with the plug-in or the mobile app from Samsung - correct?
Yes, you are correct. The limitation that was mentioned with the app was turning on as the connection is not available. I believe @antor did write more details on his website but you would need to research it.
The alternative to SQ Blaster is the Global Cache family of devices. I have both and they do the same but mainly use the GC itach as my main AV system is setup using iRule. It may also be easier to buy as the SQ Blaster is getting harder to acquire and the itach is also cheaper.
Seems like Global Cache is more actively maintained than SQ Blaster. Maybe I’ll try that out. However, I only see a plug-in for the GC100 not the iTach
It works for the itach but the flex has a different API. There was some posts of the forum which RTS chimed in and was looking into it but I cannot remember if the code was updated.
You are using the iTach and not the flex correct?
Yes, that is correct, I have the itach and also GC100/18 in different locations.
They are available through my Vera for a few things but I normally use another application (irule) to setup and control my main AV.
Here was the thread on the Flex no advancement to modify the gc100 to add compatibility as yet.
For now I was playing around with the Samsung plug-in (http://www.antor.fr/apps/samsung-tv-remote/) however I’m not sure what the best way to sequence a set of keys as scene. Do I use LUA? If so can anyone give some sample code? I’m a Java guy and haven’t found a good example of the LUA code I’d need.
You should be able to achieve sequence utilising the Advanced tab of the scene. The thread below in the last few post this is what was being discussed.
http://forum.micasaverde.com/index.php/topic,16504.msg126940.html#msg126940
Can someone teach me? How Vera communicate with SQBlaster? Are they communicate through WiFi or through Z-Wave RF? It is because I am using Europe version Vera which has a different frequency from US.
My main purpose is to put all my 7 IR controllers in my bad room into one (iOS or android), yet I can use the Vera Scene to turn them off or on at certain time.
Appreciate if anyone can share.
L3H…
Very sorry, I have one more question. How about ITach? It is communicating with Vera through WiFi?
Thank you.
L3H…
Vera communicates with either SQ Blaster or itach over your network (http/tcp) Depending on the models of itach, there is both a wired and wifi model which connect to your network which could be directly to your Vera, in the case of a Vera 3. Neither use z-wave. Both can use a ir blaster which enables it to send ir to more than piece of equipment
Hi Brientim,
Thank you very much. This is very helpful. I am going to get it.
L3H…
[quote=“L3handyman”]Hi Brientim,
L3H…[/quote]
At the moment, it is very hard to get the SQ Blaster and the itach might be the only option anyway.
