Turning on garage light with mimolite controled sensor, odd issue?
I have a mimolite controlling my garage opener, and also have the sensor that triggers motion when the magnetic contact seperates when the door is open. I setup a scene that when the motion sensor child device detects motion to turn on the light, and this works great. However I also have a scene setup to turn off the light when the door is closed causing the sensor to get a value of “0” no motion.
The interesting thing is if I leave the garage door open, after a little bit the light turns off, it seems the scene that should only activate when the sensor is closed “no motion” runs somehow. I am wondering if there is a timer value on these devices that resets after an elapsed period.
thanks
