Turn on z-wave device when furnace fan active
Has anyone found a way to turn on a device when their furnace fan is active? I have a booster fan in a duct that I’d like to convert from a wall switch to automatically running whenever the furnace fan is on. I already have a z-wave thermostat (honeywell), but can’t see any way to accomplish this via either a scene nor via luup.
There’s nothing in scenes that seems to be able to trigger off of whether the fan is running or not. (I’d be fine if it triggered off of actually heating as well, vs. just having the fan on circulating.)
I’ve already looked at urn:upnp-org:serviceId:FanSpeed1… GetFanSpeed, GetFanSpeedTarget both return null. urn:upnp-org:serviceId:HVAC_FanOperatingMode1 GetFanStatus also always returns null.
Any bright ideas that I’m missing, or can this simply not be done with Vera? (edge on UI7, in case it matters.)
Thanks.
