"Turn All Off" wrong (sub)device
I have a Fibaro double relay with one half running my pond pump and the other the pond lights.
It works fine with my Vera Plus (apart from it not recognising the energy monitoring on the second channel, a different problem), except for one thing:
  • I’ve set the categories and sub-categories so the light switch is recognised as part of the lighting, and appears correctly in the “All Lights” summary
  • The pump switch is not in this category, and correctly does not appear in the count
  • But - when I do the “Turn All On” or Off switch, it changes the pump switch! ::slight_smile:
Has anyone experienced this? Do anyone know of some settings I can change to make it work?
I could swap the relay wiring, but it’s not very accessible and anyway (1) it should work properly (2) I’m not convinced it wouldn’t just expose some other edge case
You could try setting parameter 1 to 0. That tells the Fibaro to ignore all on/all off commands.
Thanks, but that only applies to the single relay, there doesn’t seem to be an equivalent for the double relay.
They list it in the double relay manual. Wouldn’t hurt to try it. However my guess is that it has something to do with parent child devices and where you set the sub catgory.
Thanks - do you have a softcopy of that manual? My version doesn’t list that option, so I’m wondering if it’s different firmware or something.
When I add it as “poll only” it doesn’t retrieve anything, so I’m a bit cautious about trying to set it.
If it doesn’t poll it doesn’t exist.
Thanks, would have been rather useful :frowning:
