Hello,
I have a light in our porch, and a light outside. Currently these are independently controlled using two switches, connected at the same pattress box. There are only two wires for each switch, so I believe this makes it a two wire? This means that I have to use two fibaro dimmers rather than one 2x1.5kw switch module, as that requires 3 wire.
Rather than using two, I would be happy for both lights to come on at the same time, so need to hook them up together. My understanding is that I only need to basically connect the two live to the same switch, and the two neutral to the same switch. I’ve attached two pictures, one of the current setup, and the other of what I am proposing.
Would this work? If so, then I can just wire up the fibaro dimmer as I would normally.
Thanks for the help.
