All,
Just wondering if this is the correct URL to unlock a door? The identifying information is fake.
https://fwd1.mios.com/jpe/byunngle/35044444/data_request?id=variableset&DeviceNum=3&serviceId=urn:micasaverde-com:serviceId:DoorLock1&Variable=Status&Value=1
When I enter that URL in a browser I get Ok but the door does not unlock. I checked the Luup logs and do not see a corresponding entry when I run the URL.
Any suggestions? I get Ok in the web browser when I enter the URL, but there is no entry in LuaUPnP.log
John
P.s. I am using a Veralite, UI5
No, you do not use variableset. Variableset should only be used to setting the values of the variables. In order to have a device actually perform an action, you’ll need to call the lu_action api.
https://fwd1.mios.com/jpe/byunngle/35044444/data_request?id=lu_action&output_format=json&serviceId=urn:micasaverde-com:serviceId:DoorLock1&DeviceNum=3&action=SetTarget&newTargetValue=1
I suggest you look at the following:
http://wiki.micasaverde.com/index.php/Luup_Devices
I know exactly what you are talking about. My URL only returns the variable? But the action actually does something
Thanks your link was all I needed to get it working!
I feel so stupid now. I should have noticed the variable part. Thanks again,
Now I may try more things to do with Luup. I need some ideas. My first task is to hookup some automated blinds in my bedroom.
