Hi, first post, be gentle, I hope you guys can help me. I’ve spent hours and hours trawling sites and testing scripts and I’m yet to have any success. Here’s what I’m trying to do, basically I have electric window blinds that close at dusk based. If a window is open then the blind catches on the window lever and the blind gets curled up etc. I have a timed scene on my Vera Lite that closes the blinds at dusk but I want to put a check in place to see if the windows are closed first. If they are not closed I’d like the Vera to check again every 5 minutes for say, 2 hours, and then if closed, continue with the scene (and close the blind). I have Fibaro window sensors on the windows. t I’m struggling to get the very first part of this working let alone the time delay and recheck. So, any pointers very gratefully received. Here’s my simple code. It doesn’t error but when I run it the blind closes regardless of the Tripped setting.
if (luup.variable_get(“urn:schemas-micasaverde-com:device:MotionSensor:1”, “Tripped”, 21) == “1” ) then
return false
else
return true
Have had a look at PLEG and can’t fathom it.
