Trying to reduce notifications from Kwikset
I’ve been going through documentation but have yet to find something that is understandable regarding timeframes. Specifically for this task I have a VeraLite 3 and a Kwikset lock. I want to be notified of any door unlocks between 7:30 am and 5pm Monday-Friday, and 9:30pm-8am Sat-Sun. Can someone point me to a resource on this? I am not a programmer.
Thank you,
DC
This does not have to be specific to the doorlock. If there is anything that I can use to build the conditions, that’d be helpful.
Without LUUP, code, etc…
What kind of notifications? The built-in MiOS provided ones?
Create a virtual switch and scenes that turn it on when you want notifications and off when you don’t.
Create a combination switch that is on when 2 conditions are true:
  • Virtual switch is on
  • Door is unlocked
Create a new notifications in the Notifications Tab of the Combination switch for when it turns on.
Hi PurdueGuy,
Thanks for your reply. In terms of notifications, all I need are text notifications.
I’ll look up your suggestions in the meantime. Thank you!
Thank you,
DC
