I’m currently testing a scene controller - a keyfob - https://www.aliexpress.com/item/1005002552956029.html. I’ve got one that isn’t tied to a particular gateway device or anything that I can tell. I’ve managed to pair it (over Zigbee) with the controller, and it appears as a device. I had to change device_file, device_json, category_num to match a proper scene controller (D_SceneController1.xml, D_CentralSceneController1.json, 9) to make it a scene controller.
This all seemed to work OK, and Vera sees the device and you can configure the buttons for different scene’s.
The problem is, when I press a button on the keyfob, I get an error message like “Incorrect PIN code entered. Access denied”
Now whilst this isn’t formally supported by the vendor or Vera, I was hoping to get something working, otherwise may end up doing something else…
I have tried researching this error message and plenty of other things, but can’t find any reference to what might be causing this.
Was hoping that someone here might have a clue about what/how to setup the PIN properly, or at least make it work! I’m pretty much out of ideas for now.
Do you have by any chance the reference of the keyfob? The AliExpress link doesn’t provide a device reference to work with. If you can check it perhaps on the label and let us know that’d be highly appreciated!
Additionally to that, if you can enable remote access on your controller so we can take a look and send the remote access code to me via PM, we’ll try to investigate and see what we can find out.
There is nothing under the battery cover either. The manual refers to M420-73Ever1.0
After much research and checking, I had thought it should work given it’s Zigbee 3 and not tied to another manufacturer hub etc. It’s certainly close. And being Zigbee we don’t have the frequency constraints and it’s quite cheap (compared to other options anyway…)
Certainly, there’s not much information about this keyfob. The manufacturer provides little to no documentation about it and the fact that this device is ZigBee 3.0 and not ZigBee 1.2 HA makes things quite difficult. You can check the ZigBee features of Vera controllers on this page.
This is the description of the cluster that is being affected.
Unfortunately, there’s not much we can really do to configure the value that is affecting the cluster. Since ZigBee is quite more limited than Z-Wave in terms of configurations, we don’t really have the freedom to change the device parameters as most Z-Wave devices are capable of.
