Hello all, I am new to the world of Vera and recently installed about 10 Z-Wave Switches/Dimmers along with an AD2USB module to control my Honeywell Vista 20p security system. So far I have not had any problems setting up scenes and integrating with my Nest and z-wave door locks. I have even managed to configure Vera to disarm my security system if the correct code is used to unlock the front door. I have however found one thing I would think to be trivial that I can’t seem to make work.
I want to configure things so that if the security system is armed in away mode and I enter the side door, which will cause the entry delay to become active, to turn on a few lights that are near by. If I go to setup a new scene there is no entry delay options under triggers for my security system/partition but there is an exit delay which I find confusing. I ended up downloading the app “Combination Switch” which has the option for my security system/partition for entry delay - I then tried to tie that switch to a trigger in a scene but it just does not work. What am I missing here? Any help is appreciated.
It doesn’t look like there’s any mention of EntryDelay in the source for the AD2USB plugin. Looks like Entry Delay is not detectable on Vera for that alarm system.
Workaround: use the Combination Switch or PLEG to fire when the door sensor is tripped AND the partition is armed. In effect, fake your own entry delay.
Workaround: use the Combination Switch or PLEG to fire when the door sensor is tripped AND the partition is armed. In effect, fake your own entry delay.[/quote]
I appreciate the tip from both of you but I have tried this suggestion and it does not work; I have even simplified it and setup a scene where one light is turned by a trigger of one door being opened… It works fine while the security system is not armed however once the entry delay starts the trigger does not work. Here is why I think this is the case, this plugin/USB module is only looking at keypad display to get it’s data, it’s even stated in the documentation that to view faulted zone’s the plugin is sending a “*” to the panel so it will cycle through faulted zones. Seems to me this is not an efficient way of handling this as this panel does support report codes over the LRR which is how a product I am using for monitoring, from a company called ipDataTel, works. I wish I could have tapped into it but they don’t seem to have any API’s published.
I sure was hoping that someone else had seen this same problem, would have thought this to be a standard scene people would set up.
Some of the alarm panel plugins are marvels of hackery and testament to the ingenuity of the developer to work around limitations. Sounds like the Honeywell one is no exception. Simplicity and completeness of the interface is one of the reasons that forum members recommend the DSC alarm panel over other brands. Which works against you here, because most forum members (me included) have a different brand of alarm system to you and we can’t offer anything more than generic advice.
I understand completely; some of my reading today on the forums showed me pretty quick the DSC seems to be the panel of choice… I know some DSC but I know more about Honeywell as I have helped many friends put in one of those systems. Switching to DSC would be costly for me as all of my sensors are recessed wireless requiring all of that gear to be replaced. Ugh, this is the one feature I was looking forward to; I hope the developer of this plugin can help - that’s my next stop. Again thanks guys…
Since all your sensors are wireless this is easy to accomplish using the latest code in the trunk and inputting the serial number and the loop number in the cheat sheet. Then the sensors will show correct status even when armed. Have a look through the ad2usb sub forum in the plugin development section
