Trouble with Schlage lock in specific location.
I am having all sorts of trouble with a Schlage lock on my garage back door. The unit is about 40 feet from my Verde through a few walls but is right next to a GE Jasco light switch that works fine. I’ve also put an Aeon z-wave repeater in proximity to try to fix the problem but no luck. The only way the lock works is if I bring it close to my Verde. It’s almost as if the signals to the lock are not going through the network but just straight to the Verde. I have 2 other identical locks that work fine.
I have already done the following:
  1. tried a different lock - no luck.
  2. tried network heal - no luck.
  3. installed repeater close to the lock in various locations - no luck.
  4. excluded and included multiple times - no luck.
  5. tried bringing the lock close to the Verde - lock works
  6. tried new batteries in the lock - no luck.
It behaves as if the lock is not getting the signal, but there is a light switch inches away that does. I have though about trying to measure the signal, but not really sure how to go about that.
I will be submitting a help ticket, but any ideas?
Thanks!
PD
At the direction of MCV support I performed a heal without “Configure all Nodes” checked…
After this is done the lock is now working.
I’m curious why it worked this time and none of the others?
PD
