Trouble getting started with mysensors gateway
I have a VERA PLUS controller, a mysensors serial gateway(ftdi) and a water leak sensor.
I am trying to get the VERA controller setup to use the serial gateway.
I have uploaded the luup files to the controller.
However, when I created the device I got this error:
GET_LANG(system_error, System error) Device 21. Fail to load implementation file Arduino1.xml.
MySensors plugin: Choose the Serial Port.
My serial gateway is attached to the only USB port on the Vera Plus controller. Where do I find the serial port number?
