Trouble getting PLEG to work with Vera Proximity
I’m having a dickens of a time getting my pleg code to properly switch my modes from home → away.
This is all about getting geofencing working the way it should for two people (L and S).
I’m pretty sure I have Vera Proximity working right. I have three fences. largest sets to rapid updating next sets an “outer” multibutton, smallest sets to “inner” multibutton.
Multibutton Setup:
1 Inner for L
2 Outer for L
3 Inner for S
4 Outer for S
Here is the status from pleg… i cant figure out why the dang thing isn’t triggering the Home and Away actions. It is something in the conditions… i’m perplexed. Help please:
PLC Version:7.46Program Logic Event Generator[25]
2016-01-31 19:36:06.446
Registration
Installed: Wed Mar 04 2015. You have 1 license, which allows a total of 4 PLEG and/or PLTS plugins.
Triggers
Name Description State Last True Last False
tLInner MultiSwitch Switch 1 is turned on false 2016-01-31 19:32:42.420 2016-01-31 19:32:49.402
tLOuter MultiSwitch Switch 2 is turned on false 2016-01-31 19:32:38.971 2016-01-31 19:32:50.852
tSInner MultiSwitch Switch 3 is turned on false 2016-01-31 19:34:00.043 2016-01-31 19:34:06.717
tSOuter MultiSwitch Switch 4 is turned on false 2016-01-31 19:34:02.581 2016-01-31 19:34:05.076
Modes
Mode Name State Last True Last False
Home mHome true 2016-01-31 18:29:08.106 2016-01-31 18:28:53.132
Away mAway false 2016-01-31 18:28:53.136 2016-01-31 18:29:08.102
Night mNight false 0 0
Vacation mVacation false 0 0
Device Properties
Name Device Name Device Variable Value Last Change Previous Change
coolSetPoint Kitchen Thermostat CurrentSetpoint 68 2016-01-31 18:29:22.001 2016-01-31 18:25:48.102
cTemp Kitchen Thermostat CurrentTemperature 69.5 2016-01-31 17:38:52.942 2016-01-31 16:44:13.074
heatSetPoint Kitchen Thermostat CurrentSetpoint 76 2016-01-28 18:45:44.119 0
Conditions
Name Repeat Expression State Last True Last False
cNeedsHeat No cTemp < coolSetPoint false 2016-01-31 09:27:40.223 2016-01-31 10:01:11.522
Comments: Thermostat setpoint is higher then current temperature.
cNoMoreHeat No cTemp > coolSetPoint true 2016-01-31 10:01:11.522 2016-01-31 09:27:40.235
Comments: Current temperature reaches setpoing
cHome No (mAway or mVacation) and ((tLOuter and tLInner) and (tLOuter;tLInner)) false 0 0
cAway No mHome and !((tLOuter and tLInner) and (tLOuter;tLInner)) and (mHome;!tLOuter) and (mHome;!tLInner) true 2016-01-31 19:32:50.873 2016-01-31 19:32:39.005
cLHome No (tLOuter and tLInner) and (tLOuter;tLInner) false 2016-01-31 19:32:42.431 2016-01-31 19:32:49.433
cSHome No (tSOuter and tSInner) and (tSOuter;tSInner) undefined undefined undefined
Actions
Actions for Condition: cNeedsHeat
Device Actions:
Immediate
Device Action Arguments
Fireplace Blower SetTarget newTargetValue=1
Fireplace Gas SetTarget newTargetValue=1
Actions for Condition: cNoMoreHeat
Device Actions:
Immediate
Fireplace Blower SetTarget newTargetValue=0
Fireplace Gas SetTarget newTargetValue=0
No assistance huh? That is disappointing. Have I not provided enough info?
You need to post your “Status” Report in PDF form. Copying and pasting is hard to read.
Thanks for the feedback. I’d seen many posts with just the copy/paste of the status, but the pdf is much easier to read.
I had been playing around with it and so I deleted the info and started over. Not a complete rework but it should at least set vera to home mode when first the outer, then inner switches are tripped for a person.
The conditions seem to think I’ve done something horrible.
Thanks in advance for any assistance anyone can provide.
The “unidentified” in your current status of the 3 conditions are your issue. Have you reloaded lupp and refreshed the webpage? Do you get any errors red banner acfoss the top of the ui in vera?
Have you tryed putting a space after the “;” in the conditions.
Like this (TLoutter; tLinner)?
