I recently upgraded to UI7.
Everything appears to be working with my devices. PLEG survived the update and seems to be working for all of the things I have tested. The problem is the GUI. I cannot change anything. The GUI doesn’t appear to render the PLEG menus properly.
I’m on PLC 7.45
PLEG and PLTS are both 7.45 as well
I couldn’t find others having these issues so I’m thinking something is not right with my system.
This is what I have noticed issues with so far:
The status page is blank but the report works.
triggers display but cannot be edited
Device properties will let you edit them but there is no longer a drop down, you have to type in the property.
Conditions brings up a table but the condition expression is empty. clicking Edit brings up the editor which is also empty.
action table appears but clicking edit does nothing.
You need to UPGRADE the PLEG, and PLC (in that order) after you upgrade or downgrade.
See: http://forum.micasaverde.com/index.php/topic,14446.0.html
[quote=“RichardTSchaefer, post:2, topic:187336”]You need to UPGRADE the PLEG, and PLC (in that order) after you upgrade or downgrade.
See: http://forum.micasaverde.com/index.php/topic,14446.0.html[/quote]
To add to this he means even if you have the latest you still need to upgrade again.
OK, I figured it was the latest version so it didn’t need updating. I assume the update configures the plugin based on which UI is loaded… makes sense.
I ran through each one in order per the instructions. I received the OK and waited for LUA restart. Unfortunately I’m still seeing the same results. I see in the end of the update post somebody else was having issues with icons. Mine also don’t appear.
[quote=“Moxified, post:4, topic:187336”]OK, I figured it was the latest version so it didn’t need updating. I assume the update configures the plugin based on which UI is loaded… makes sense.
I ran through each one in order per the instructions. I received the OK and waited for LUA restart. Unfortunately I’m still seeing the same results. I see in the end of the update post somebody else was having issues with icons. Mine also don’t appear.[/quote]
Screen shot?
Are they on the bottom vs. the top?
is what on the bottom vs top? I have included some shots of what I’m seeing.
Reload Vera one more time … that will put many of the menu’s on top …
But you also need to refresh your browser !
The Vera TWO step is very common when things do not work right:
1) Reload Vera … Wait for it to finish (Let’s Vera start using the most recently changed things!)
2) Refresh the browser (Removes it’s knowledge of the OLD stuff!)
AH, a force browser refresh fixed it. Everything looks good for the moment!
