Totally confused.
I hope someone is able to help me … ???
I use this code :
[sub]local lul_tmp = luup.variable_get(“urn:micasaverde-com:serviceId:SecuritySensor1”,“Tripped”,62)
if (lul_tmp==“0”)
then local lul_tmp1 = luup.variable_get(“urn:micasaverde-com:serviceId:SecuritySensor1”,“Tripped”,63)
if (lul_tmp1==“0”)
then luup.call_action(“urn:upnp-org:serviceId:SwitchPower1”,“SetTarget”,{newTargetValue=“0”},61)
end[/sub]
When both pc running at the office are powered down , the ping sensor is not tripped.
When I run the scene manual , the switch will go off . So I will assume the scene is working.
I have added a timer , witch is running every hour to check the pc’s are not running any more and will switch off the printers. ( like i tested manual ) .
This will not working :o :o
Can you please point me into the right direction …?
Many thanks in advance
[quote=“mversluis, post:23, topic:167050”]Totally confused.
I use this code :
if (lul_tmp==“0”)
if (lul_tmp1==“0”)
end[/sub]
best regards,
Marco[/quote] @mversluis
If you are still following this thread, triggering a scene was a problem for many people until @pepebel4 came up with the json code add for the D_PingSensor.xml
Have you ever checked that codesnippet was in your xml?
