can someone recommend me a flood-sensor which Not drains the battery if it is tripped all the time ?
i noticed serval battery powered devices do have this effect.
i need a sensor to monitor a certain water level, so the sensor should work reversed report if the water is gone (so to say)
You could probably modify a FortrezZ WWA02 by replacing the battery with an AC adapter and sealing it up with silicone caulk (as long as you have the proper DC input voltage). That being said my WWA02 lost its mind (reporting water when it’s dry, saying it’s either 5 or 127 degrees).
Or rig up a contact closure (as in an alarm system) and two probes that complete the circuit when both are immersed (low power of course).
FortrezZ hardware is insanely overpriced.
and in this special case i can not have any cables (well i could but it’s abit tricky one)
i have a storage shelf. its resting on 4 pots filled with water (to keep the ants away)
so i just wanted to be alterted if the water gets low.
a power cable would build a very nice bridge for the ants to bypass the water …
here in Thailand this Beasts are amazingly fast in finding such shortcuts.
we almost always forget to refill the water, so i was thinking of some notification for that …
thats why the sensor would be always tripped … (because water is good in this case)
I’ve read that Ants aren’t fond of Borax or cinnamon (never tried it though). Borax is supposed to cut them up, and cinnamon is supposed to be something they hate.
I lived in Singapore for a while, so I know how annoyingly aggressive the ants are in Asia.
If you have anything like an alarm panel tied into your Vera, this article describes how a WaterBug water sensor would alarm when water is not present.
