Trip/trigger Smoke Alarm from VeraEdge
Can I somehow trip the Smoke Alarm on my other Fibaro Smoke Sensors from VeraEdge when one sensor is tripping? Via LUUP-code or something?
I believed all my Smoke Sensors would alarm if just one sensed the smoke, but I was wrong. They do not tripp each other as I know. ???
Im about to buy 3 of the fibaro smoke sensors so if this can’t be done please tell me before I buy.
Regards
Myren
Skickat fr?n min iPhone med Tapatalk
I do not know yet, I am still to find out how to trip them all off if one is detecting smoke.
They will trigger other units but only via a wired NC connection I believe. If they are battery powered they definitely won’t as they won’t be listening constantly to zwave signals. No reason why they shouldn’t if on mains power but think that would rely on them having functionality to be activated over zwave which is probably not a good thing as then they would be used for other purposes which likely is against building regs.
I believe that it is correct that only sensors with hard wired connection between them can do this. I do notthink any z-wave smoke sensors have this but I may be wrong. I do not believe that the smoke alarm can be triggered from the Vera either.
@Slartibartfast
i dont think so.
Smoke Detector / Wireless Siren - Popp (Produkter för hemautomation & smarta hem | M.nu)
this one says "it alarms acoustically and sends alarm signal to Z-Wave network so that all other smoke detectors in range can be alarmed. That ensures that the alert also reaches people in all floors as well as in the night while they are sleeping. "
sounds like is should be possible using Z-Wave
That product though is a combined z wave smoke detector and siren, specially with a different sound for manually activated sounds.
So yes looks like there are products that do it, just likely not the fibaro ones.
