triggers not working in UI7
I received today my vera edge with UI7
Until a few days i was running UI5 (vera lite), I restored a backup with all my scenes and apps.
Sadly the zwave devices where not restored so i had to include them all manually again.
I found the following anoying problem:
  • scene triggers do not seem to work, when i add one and i activate a device for the trigger the scene is NOT run in any way, running the scene manually works fine.
How can i fix this, almost all my scenes include triggers, none of them work now.
One thing you can check the option “running this scene in mode” and if the correct option is checked for your scene.
nope, i factory resetted the device and had to setup all again manually
Same thing happened to me after upgrading, the next run never showed a date and scenes would not run. Looked at “Run Scene in Mode” and none were selected. Checked every one and it began working. Thanks for the tip.
