I just got my first vera for Christmas and have started learning everything I can about automating things with scenes. One quick question which I have been unable to find an answer to so far…
If I create a scene and attach a trigger to it, will the scene only execute once the trigger condition is met initially (the first unique change)? Or will it continuously trigger as long as a trigger continues to be met?
Let me explain this a little clearer…I am using the iPhone location add in for my controller. I have created a scene that switches my Nest thermostat into AWAY mode as soon as my iPhone status changes from PRESENT to AWAY. This works, but is my controller constantly sending AWAY triggers and constantly executing my scene as long as I stay away from my house? Or does the scene only trigger once when a new unique status is detected from the iPhone plugin (ie. the initial PRESENT to AWAY status change)?
Hope I’ve explained myself correctly and I hope someone knows the answer to this.
Thanks.
