I am trying to get PLEG to run scenes. I have added my instance of PLEG under Actions → Edit → Advanced and then RunScene.
I have entered the scene number from the Automation → Scenes tab in Vera but I still can’t get it to work. I have also tried the name of the scene. Using a VS to check out the settings.
Attached are screenshots of the Automation tab and the Advanced tab in PLEG.
Another scene related question… Is it possible to make an input to trigger something when a scene is activated? I have something called “_Scene Controller” amongst my devices under Inputs, but I can’t seem to have this recognize when a specific scene is activated even though the correct scene number is filled in.
There isn’t any built-in way to have a scene trigger PLEG. The simple solution is to have the scene(s) set a VirtualSwitch or MultiSwitch which can be used as a trigger in PLEG. If you use VirtualSwitch, you would need PLEG to turn it off. MultiSwitch can be set so the switch turns off automatically after a short pulse.
