Is it possible to trigger a scene from the keypad?
I was reading on the Vista systems this was possible by hooking an I/O module up to one of the relays on the alarm panel. Can you do the same with DSC? IS there a more direct way?
Any info is appreciated.
Depending on which DSC panel you have, then you can trigger 2 to 4 using the onboard PGM and some 12V relays connected to some spare zone inputs. If you have a look in the main alarm thread for the DSC using the search, you should find a post from me detailing this a bit more.
