Trigger for light
I have a GE link light that I moved from one location to another location. It is turning on ‘randomly’ and I cannot find the scene that is causing the light to trigger.
Is there any way to check logs to see what ‘event’ caused the light to turn on?
You can check the log using your browser http://vera_ip/cgi-bin/cmh/log.sh?Device=LuaUPnP. You can also viuw the log using ssh.
Or you can check in which scenes the device is used in Ui7, open the devices tab and check the last option scenes.
Thanks for the help Ranneman!
