Hello guys
I have a SAMSUNG SMART TV at last
I couldn’t find application in the app store
Does any1 have it so i can manage to download it via USB?
Or is there any alternative app
Regards,
Hello guys
Regards,
Same problem here… Anybody an idea?
You have to contact tricktv support. It’s still in beta. Once they confirm you have a tricktv device they will send a link and install instructions. It also requires you go through an activation step on tricktv, an option that isn’t available on the Vera UI.
I contacted them but no reply
You mean i cant make trickTV work with Vera only?I need to buy the hardware they produce?
Although I have read the opposite
[quote=“therealabdo, post:4, topic:174758”]You mean i cant make trickTV work with Vera only?I need to buy the hardware they produce?
Although I have read the opposite[/quote]
Too bad, I would pay for the app if it worked with VERA…
