1,5 years ago I bought a Vera Lite
since day one I have had one problem and that is that it not communicate with the devices in a good way
Almost … every time I try light up a lamp so it says …
Waiting for node to reply after 1 retries
Sending the Z-Wave command after 1 retries
Waiting for node to reply after 2 retries
Sending the Z-Wave command after 2 retries
Waiting for node to reply after 3 retries
Sending the Z-Wave command after 3 retries
Waiting for node to reply after 4 retries
Sending the Z-Wave command after 4 retries
Transmit failed with code: 2
The swiches I use is Fibaro FGS221, FGD211, FGS211
first I thought it could be “bad reception” so I mounted an external antenna
and range got better but the problems did not disappear.
This is a signal/route quality issue. @Bulldoglowell provided a decent suggestion, but if the problem has been occurring for a year and a half, there have already been many heals.
Signal/route quality issues are resolved by adding intermediate nodes. You need to add more nodes between Vera and the problem device(s).
[quote=“chin, post:1, topic:179945”]first I thought it could be “bad reception” so I mounted an external antenna
and range got better but the problems did not disappear.[/quote]
The antenna made it better, but not good enough, additional nodes are needed.
I have three nodes in total, sounds strange that you cant make them work without buying more nodes.
I will try to move vera to the same room as the “problem” node.
It may sound strange to you, but its a one of the characteristics/benefits of mesh networks. An excellent and detailed explanation can be found here at Vesternet.
