I NEED HELP! I JUST INSTALLED A TRANE XL950 THERMOSTAT. WHEN I BOOT IT UP IT SAYS THERE IS AN ERROR AND IT NEEDS SET UP. THE MANUAL SAYS TO GO TO INSTALLERS MENU TO SET UP. ACCORDING TO THE MANUAL ITS UNDER THE SERVICE MENU. WHEN I GO TO THE SERVICE MENU IT JUST GIVES ME A SPOT TO ENTER THE TRANE DEALERS INFO. THE LOWER RIGHT HAS A SELECTION FOR TECHNICIANS MENU BUT IT DOESN’T DO ANYTHING WHEN I TOUCH IT. HELP!
The last I heard the thermostat is not compatible with Vera.
http://forum.micasaverde.com/index.php?topic=7017.0
- Garrett
Is there a hard reset or internal battery you can pull?
