I’m looking at replacing an existing tstat that is battery powered, and hooked up using 2 wires.
There is no A/C, no fan, just a boiler that drives steam radiators throughout the house.
I did pull the cover off the boiler, and there is a 24v connection. Running new wire for the necessary power conductors should not be a problem.
So, assuming I can wire it up correctly, is there any reason this tstat won’t work for me? The installation manual was a little vague. Something like “may or may not work on boilers”.
Thanks in advance.
