I have a Good Night scene and a Good Morning scene both of which I created in UI4 1047 on my Vera 2 and both of which do only one thing: change the heating and cooling temperatures on my Trane thermostats.
When I run these scenes from UI4 they work without issue. However, when I assign the scenes to any of my Leviton 4 button scene controllers (or even a 1 button scene controller), they refuse to run. The LED lights up for an instant on the controller to indicate a button press but the temperatures never change on the thermostats.
Is there any reason a Leviton scene controller can’t run a scene that changes a thermostat temperature?
thanks in advance for any responses,
berylium
Do you have it setup so that the button press controls a scene in Vera or is it trying to directly talk to the devices?
ASIHome,
I did not program the scene controllers to talk directly to the thermostats. I created the scenes in UI4 1047 on my Vera 2 then I edited my scene controller devices, also in UI4, and added the scenes to a button on the scene controllers. When I save the scene controller devices show those buttons linked to the scenes, however, pressing those buttons on the controllers does nothing.
-berylium
What scene numbers are you using? Some of the Leviton’s use 1,2,3,4 and some use 0,1,2,3.
I have four 4 button scene controllers and one 1 button scene controller, all Leviton. According to the SceneShortcuts and Scenes variables each controller starts with button 1. I don’t see a button 0 anywhere.
-berylium
That’s weird. I have an identical configuration – trane thermostat, vera 2, leviton switches – and I am able to use a leviton 4-button scene controller to activate a scene (originally configured in UI4) that turns on lights and sets the thermostat. It works 100% of the time. So it doesn’t sound like a hardware incompatibility.
Have you re-included the scene controller on Vera?
