Does anyone know if it is possible to use some luup code to change the Trane thermostat “user settings”? Or is this not possible to do with Vera? Specifically what I’d like to do is be able to write some code within a scene that will change the “Back lite/Display” timeout so during the day the timeout is set to default 30 seconds and at night it is set to 0 (on all the time). I’m assuming this won’t be possible but I figured I would ask if anyone has done this before or inquired about it and got some resolution.
Thanks,
Ray
